Home › Forums › Products › Stompboxes › Space › Reply To: Space
March 1, 2011 at 9:41 am
#132864
guitarlesson:
Wait, so just for ABSOLUTE clarity… you can use 4 OneSpots to power 4 factors, but you cannot chain them to one supply, right? I understand that one OneSpot would probable not supply enough amps since my TF requires 1.2, but isolation is something I know little about. Thanks.
Yes that is correct. basically you have to have one power supply dedicated to one factor. you can not have multiple factors on the same onespot or even a simple compressor and a factor on the same onespot.
The exception to this is the power supplies that isolate each output…. like the powerfactor etc…. these power supplies are usually a lot more expensive.
