Home Forums Products Stompboxes Problem with TF and gain channel Reply To: Problem with TF and gain channel
#132877
i've gone thru about every cable i have and they all lead to the same hiss. wall wart configuration was no change. i've tried keeping the two apart from each other on different outlets as well.
bypass settings were on DSY… i tried all three. the only noticable difference was on relay setting. when my effects were off. the hiss almost went away.  but as soon as I engaged the pedal it was back. this is probably going to be the bypass setting i use from now on. when im using high gain I usually dont have the delay on anyway. but with the relay settings I wont hear the hiss when its off. this is a plus but it doesnt solve the issue for me. kinda more like a bandaid…
