Home Forums Products Stompboxes expression pedal: no sound, but parameters on display changing Reply To: expression pedal: no sound, but parameters on display changing
#132919
    We don't have experience with the Korg pedal, but it should work. You will need to connect the EXPRESSION (output) connection to the 'Factor, and adjust the volume knob for best results. It is more likely to work if you use a mono (tip,sleeve, no ring) guitar-type cable. Not all presets have expression pedal settings.
    Maybe someone out there has one working ?
