Home › Forums › Products › Stompboxes › The final frontier? › Reply To: The final frontier?
#132977
rabiddiabetic13
    Yes you are correct about the Hi EQ boost/cut.   I am tweaking those presets with Hi EQ boost above 60 to around 50 or lower to get rid of the noise.  All my distortion pedals are noisy but I run them thru the send and return of a boss noise gate but I certainly don't want to run my SPACE thru it and cut off the reverb decay that  is why I suggested the gate for that algorithm.
    Space as definitely made my  setup sound more lively like I took a blanket of my amps.
    Thanks for your input Tim
    Anthony
