Home › Forums › Products › Stompboxes › Ideas for Pitchfactor update › Reply To: Ideas for Pitchfactor update
March 17, 2011 at 8:11 pm
#132978
I can't imagine it would be that difficult to sync the two as the Factors have great Midi Sync abilities.
you would set one as the "Master" set it to transmit midi and time and then connect them up with a midi cable. set the master as the time source and then the Slave as to slave the midi time.
Admittedly I have not set up two of the same factors, but I have used TimeFactors and PitchFactors together so I do not see why it would be any different.
it sounds more complicated to write it down than it actually is….and I was a Midi noob
