Home › Forums › Products › Stompboxes › expression pedal: no sound, but parameters on display changing › Reply To: expression pedal: no sound, but parameters on display changing
#132981
I looked at your KORG pedal specs and it might be an IMPEDANCE mismatch.  Time Factor works with expression pedal that ranges from 5K – 20K.  Your KORG pedal has an output impedance of 25K max. You should try with an expression pedal that maximum's impedance ranges between 5K and 20K.
Good luck
