Home Forums Products Stompboxes Ideas for Pitchfactor update Reply To: Ideas for Pitchfactor update
#133018
You can also use the Encoder to select the bank… might save you some time, although you'll still have to hit the footswitch to recall the preset. I've found this feature to be a little tricky (touchy maybe is a better word), but it's useful.
From the release notes for v2.3.0[2]: "In Bank Mode, the Encoder can now be used to select banks in either direction if turned within 2 seconds of pressing a bank change footswitch. "
