Home Forums Products Stompboxes ModEchoVerb Echo-vs-Reverb Balance / Space Suggestion Reply To: ModEchoVerb Echo-vs-Reverb Balance / Space Suggestion
#133021
I'm a new SPACE owner and would like to humbly thank Eventide for this amazing pedal. The SPACE stompbox is simply the best reverb I've ever had the pleasure of hearing and using with guitar, and it's a tweaker's dream to boot.
On a somewhat related note, encouraged by the depth and breadth of this product, I'm now saving away for a H8000FW. Geeked
As for update ideas:
– Separate wet only output level adjustment option?
– Hotswitch lerp…so that when the hotswitch is pressed the unit would smoothly morph between the assigned parameter settings, maybe based on an independently adjustable time/rate setting? The expression pedal allows for this kind of control, but it'd be neat to achieve a similar effect with a single switch press, in some circumstances.
Thanks again!
