Home Forums Products Stompboxes ModEchoVerb Echo-vs-Reverb Balance / Space Suggestion Reply To: ModEchoVerb Echo-vs-Reverb Balance / Space Suggestion
#133034
Har
    +1 on Noah's idea for some kind of HotSwitch morph parameters – I was
    actually just about to post some ideas on that in a separate thread but
    saw it here. Smile
    I imagine a HotSwitch transition/morph mode would need to be set up
    at preset-level as opposed to a global setting; perhaps the settings
    could be a sub-menu accessed the same way as the [HOTSW CLEAR] function
    by pressing both the HotSwitch and the encoder – and then drilling down
    further from there.
    From there, perhaps a [HOTSW MODE] menu could be available, where you could select:
    • TOGGLE – the current default HotSwitch Mode
    • MORPH – the ability to have the two sets of HotSwitch
      parameter values change by a determined rate over time. Depending on how
      the TEMPO Mode was set for the preset at hand, it could be set by
      either seconds or be note-length based, similar to the various algo's
      Decay values.
    From there, there could maybe also be a [MORPH CURVE] menu, where you could select:
    • LINEAR – the parameter changes occur in a smooth linear manner between the two sets of values.
    • EXPONENTIAL – the parameter changes sweep through initially slowly, and pick up speed towards the end of the morph.
    Of course, one could argue that you can already achieve these kinds
    of changes using an expression pedal. However, having the ability morph
    between two sets of values over time like this would give us even more
    creative control flexibility simultaneously.
    For example: imagine a preset based on the Shimmer algo where the
    SIZE parameter could be controlled this way, while the A and B
    pitch-shifters could be controlled Whammy-style with an expression
    pedal, with the preset set to Tempo Mode.
    Then imagine you step
    on the HotSwitch right on the down-beat: the SIZE parameter could slowly
    increase over, say, four or eight (or more) bars in a near-precise
    manner….while leaving your feet free to get crazy with the
    pitch-shifting using the expression pedal. I imagine a LOT of really
    wild, creative tones could be achieved this way. Cool
