Home Forums Products Stompboxes TimeFactor MIDI Tap temp half what it should be?? Reply To: TimeFactor MIDI Tap temp half what it should be??
#133091
badmelonfarmer
    do you have another MIDI device that you can set the tap tempo on and then sync the TimeFactor to that??
    I had hoped to be able to do that with my Axe-FX but it does not have MIDI clock out…DOH.
    Must also say I find the Ground Control Pro a MUCH easier box to program than the MIDIMATE….much more intuitive, so glad I made the jump.
