Reply To: Timefactor Questions – Please help.
Home Forums Products Stompboxes Timefactor Questions – Please help. Reply To: Timefactor Questions – Please help.
#133339
Tonepowers
Thanks, will do!
Is it possible to have the TimeFactor in Play mode so I can use the tap and freeze on the pedal but use the FS3X to change / set the bank? The default is obviously the reverse of this with the FS3X controlling the on / off, freeze, and tap. Since the FS3X is not mounted to my pedal board it would make setting the tap tempo easier live. What setup do you like for live use?
