Home › Forums › Products › Stompboxes › Midi Pedalboard Help › Reply To: Midi Pedalboard Help
May 13, 2011 at 1:54 pm
#133395
I too found the functionality of the gcp to be limiting. So now you've stepped up to the fractal audio MFC-101. When I drink beer I don't find more money in my wallet. Where did you get that wallet? But seriously, does the MFC play nice with your expression pedal? Are you using it with a mini amp gizmo? The OP should listen carefully as to how you've made the midi assignments work.
