Home › Forums › Products › Stompboxes › TimeFactor question: why the volume bump when the effect is engaged in mono? › Reply To: TimeFactor question: why the volume bump when the effect is engaged in mono?
May 24, 2011 at 5:47 pm
#133446
I have the same volume issue when engagin the TF. If I reduce the Wet/Dry mix, the volume bump is less. Any solutions to this issue?
