Home Forums Products Stompboxes Using all three Factors? Reply To: Using all three Factors?
#133506
hughmcm
    You'll need lots of cable?  Unless you run the Eventides (and other pedals)  from a drawer in a rack, with a midi foot controller out front.  I keep mine on the floor and although it's all midi controlled (using a Musicom), I often adjust the Eventides using their own footswitches.  I also use a three-way footswitch to the TF and MF to replicate the function of their three switches, plus tap tempo to all units, which would otherwise be a problem (at least I couldn't work out a sensible way of doing it).
