Home › Forums › Products › Stompboxes › Timefactor Patch to Patch midi Latency? › Reply To: Timefactor Patch to Patch midi Latency?
June 15, 2011 at 6:22 pm
#133526
Well I should of given some background information. Just wanted to know if I should put in a bypass loop or always in the signal chain.. My current setup's signal is overloaded with buffers and is degrading my tone. I want to use midi bypass as much as possible so I can utilize Stereo outputs. There is not much out there with stereo routing and midi capabilities and pedalboard friendly. As soon as i decide on the routing system I’ll most likely be needing more help. 🙂
