Home Forums Products Stompboxes Tap Tempo Dilemma – Ground Control with Pitch/Mod/Time Factor Combo Reply To: Tap Tempo Dilemma – Ground Control with Pitch/Mod/Time Factor Combo
#133669
badmelonfarmer
    oh by the way, in case you decide to try….
    you can not use the MIDI IN on the Ground Control Pro to merge, I tried that when I had one….it does not work….it does not merge the MIDI IN with the output unfortunately …. although it was not my preferred choice as it meant an extra MIDI cable across the stage and more agro during setup and packup.
