Home Forums Products Rackmount H8000FW routing limitations Reply To: H8000FW routing limitations
#133733
    Not quite sure what it is you want. It will be best if you can do it yourself on the Routing (for some reason I can't copy and paste graphics here.
    What you have looks reasonable, except I'm not sure why you are feeding all the dsps from Main-in 7 and 8 only. The connections to FW1 out are also criss-crossed.
