Home › Forums › Products › Stompboxes › NEW POWERFACTOR arrived seems wonky › Reply To: NEW POWERFACTOR arrived seems wonky
August 25, 2011 at 8:20 am
#133749
The DL4 will probably not work as they use AC power… Unless they have internal converters that will allow them to run on DC…. I would not risk it!
Looking at the power supply for the EHX 16Sec DD… It uses a 9v DC 500mA power supply, so it may work on one of the high output ports, just make sure you have the correct polarity lead…. Doesn't the power factor come with an EHX/Dod mini jack lead??
