Reply To: Space and Midi Clock/External Tap?
Home Forums Products Stompboxes Space and Midi Clock/External Tap? Reply To: Space and Midi Clock/External Tap?
#133792
abrasivesounds
I was able to associate the tap tempo with a cc. What's odd is that if I raise the bpm, the space will ALWAY be behind. If I lower the bpm, the space will be on beat about 80% of the time.
It still sounds slightly off even when it's synced. I put it in modechodelay mode and used strictly the delay. The repeats were a slight bit off, which creates a whole set of phasing problems when running into other pedals that have perfectly synced effects. Try running a delay at 119 into a delay at 120, into a slicer at 120. It sounds off.
The eventide stuff seems to sync well to each other, but I can't get the timeline and space to play nice together. Perhaps the reason yours works is that the eclipse has a solid midi sync in and the space reads that perfectly fine. I'm not about to buy another eventide pedal just to get the sync though 🙂
I think this is on eventide's end.
