Home Forums Products Stompboxes Eventide: MIDI Sync on Space does not work. Please fix it. Reply To: Eventide: MIDI Sync on Space does not work. Please fix it.
#133796
    As mentioned, we recognize that there is room for improvement…
    One thing to look out for – it won't respond to a small change in received tempo, as the audio effects of changes caused by this can be worse than the resulting error. So, if you go from (say) 119 to 120, it may not respond accurately. But, if you go from 100 to 120, it should be pretty much spot on (once it has settled).
