Home Forums Products Stompboxes Set delay to continue to tail off, after preset change Reply To: Set delay to continue to tail off, after preset change
#133842
badmelonfarmer
    sebastiank:
    This sounds like its more related to the way that eventide units in general work. When you load up a preset it is essentially completely changing the box as the algorithm is being loaded. So if you had an effect  with delay then switched to a different one it will cut the previous effect short as it loads the new algorithm. Setting to DSP+Effect works fine when bypassing but if you want to change the effect it will cut it short. At least thats how it works in the harmonizers.
    Cheers
    Yes, that's what I was thinking….I have not tried it between presets myself, only on the bypass on/off….but if you are loading different algorithms then I would not be surprised at all that it would not work.
    if we are talking factory presets 3:1 and 3:2 then they are definitely different algorithms 3:1 is BandDelays and 3:2 is Reverse (IRRC —off the top of my head)
