Home › Forums › Products › Stompboxes › Set delay to continue to tail off, after preset change › Reply To: Set delay to continue to tail off, after preset change
September 26, 2011 at 1:03 pm
#133849
Have you tried it using the switches on the TimeFactor in Bank mode? I know you want to control it via MIDI….just trying to see if it is the way that MIDI is working with it or if it is the actual function?
