Home Forums Products Stompboxes Set delay to continue to tail off, after preset change Reply To: Set delay to continue to tail off, after preset change
#133852
badmelonfarmer
    carlosmoreton:
    Yeah, I am using it in BANK mode.  IE send to change to 002 = Bank 1: Prest 2 etc
    No, sorry I meant use the switches on the TimeFactor to swap between presets and not the MIDI controller…..I know you don't want to do this long term…but it should help troubleshoot if the issue is in MIDI or the way the TimeFactor is working for you.
