Reply To: Share Your Presets Here!
Home Forums Products Stompboxes Share Your Presets Here! Reply To: Share Your Presets Here!
#133859
Imerkat
Tempo is turned ON or OFF by momentarily pressing the Encoder. When Tempo is ON, the
Tempo LED flashes at the Tempo rate. With Tempo OFF, the Tempo LED is OFF.
Tap Tempo
In Play Mode, the Tap Footswitch {Far Right} can be tapped to set the tempo.
