Home › Forums › Products › Stompboxes › Bypassing by CC- works but doesn’t bypass in patch change › Reply To: Bypassing by CC- works but doesn’t bypass in patch change
November 29, 2011 at 9:43 pm
#134010
Not sure it will work with your set up, sorry don't know the G-Major unit.
But I placed the TimeFactor in the FXLoop of the modellers I have used… I then ran the TimeFactor in KillDry mode, which only passes the wet signal…. You then mix in the amount of wet dry on the modeller / FX unit.
If I had a preset that I did not want the TimeFactor on for, I just did not enable the FXLoop for that preset.
In fact this is still the way I run my Eclipse and Space now.
But this depends if the G-major had an effects loop that works that way??
Cheers
Martin
