Home Forums Products Stompboxes New Timefactor User – Simple MIDI Question Reply To: New Timefactor User – Simple MIDI Question
#134046
badmelonfarmer
    you would need to go into the System menu>…
    turn the knob to MIDI> press the knob…..
    Make a note of what MIDI Channel the TimeFactor is listening on eg 2
    Turn the knob to [RCV CRTL] press the knob
    Turn the knob to [BYP] (Bypass) then set a value if one is not set eg…4
    Save the setting
    then on the Roland controller, set button 4 to transmit MIDI CC value 4 on Channel 2.
    (I do not know the Roland controller though)
    Hope that helps
    Cheers
    Martin
