Home › Forums › Products › Stompboxes › Bank mode Space vs other Factor pedals › Reply To: Bank mode Space vs other Factor pedals
December 18, 2011 at 12:58 am
#134087
+1 for setting other factor pedals to operate like the space does for preset selection.
i've also seen quite a few requests for this on the forum. certainly it could be put in as an option, only selectable through the general setup?
i found that using one factor to send MIDI is not that useful in multi – factor pedal setups since MIDI thru the chain to enable master control from an external interface is more useful.
