Home Forums Products Stompboxes Share Your Presets Here! Reply To: Share Your Presets Here!
#134155
madmac
    Hi Sparkfriction.  I don't have a sheet on these latest ones but There is a link in this thread of a sheet I did up a while back some of these presets will be the same as the latest but most have most likely been modified since to suit latest version.  If you have access to a computer you can just open the file and view the knob settings in factor lib even if you can't load it to the TF.
    Im not aware of an easy way to convert it to a excel file other that going through it manually and checking even knob, recording ect.
