Home › Forums › Products › Stompboxes › Modfactor: Problem with unit crashing and shutting down › Reply To: Modfactor: Problem with unit crashing and shutting down
January 30, 2012 at 8:51 pm
#134193
Under "Restoring Factory Settings" in the UM. This should not really be necessary, but is often a good idea to blow away the cobwebs after an upgrade, or if you are having problems.
