Home Forums Products Stompboxes Tap sync multiple units with one Reply To: Tap sync multiple units with one
#134206
wedelich
    Are you trying to use MIDICLK AND send tap information via MIDI CC?  You should probably use one or the other.   I recommend MIDICLK because it's a more generalized solution that is independent of MIDI channels.  Also make sure GLOBAL TEMPO is on.  This will help the tempo to always slave when changing presets.
    -Russ
