Home › Forums › Products › Rackmount › Rocktron ALL ACCESS/HEX expression recognition? › Reply To: Rocktron ALL ACCESS/HEX expression recognition?
February 8, 2012 at 12:32 am
#134213
So if I understand correctly, the only way I can get an expression pedal to work with the Eclipse is if I use the dedicated Pedal 1 IN on the Eclipse itself, as opposed to using the Pedal 1 IN on the Midi controller. I will have to get a longer TRS cable if I am going to accomplish this, as all I have is a little patch cable I made. I will report back if this works.
