Reply To: Multipedal setup
Home Forums Products Stompboxes Multipedal setup Reply To: Multipedal setup
#134214
Loaded6String
I'm also in dying need of this kind of midi-merge option  …trying to sync a modfactor with a T.C. G-Major II both controlled from a Rocktron All Access pedal board.
My Modfactor used to have this feature (sending clock while midi out being configured as thru), unfortunately it was removed with the V3 software.
I wrote the technical support about this many months ago, but never got an answer. ;-((
HELLO EVENTIDE STAFF, LET ME KNOW IF YOU READ THIS!?!?
As is figured out so far, the only way around this problem would be using seperate midi-thru and midi-merge boxes in front and after the modfactor…. and basically i think it's a shame that i have to consider workarounds like that for an Eventide unit that elsewhere offers an exemplary midi implementation.
regards,
René
