Home › Forums › Products › Rackmount › Rocktron ALL ACCESS/HEX expression recognition? › Reply To: Rocktron ALL ACCESS/HEX expression recognition?
February 10, 2012 at 9:48 pm
#134234
The setting I am working with is indeed, OMNI.
When trying to Capture the movement of the pedal in the External menu, the Eclipse reads out "THIS PARAMETER CANNOT BE MODULATED. PRESS ANY KEY TO CONTINUE."
When I go to the Pedal Setup menu, a similar event occurs as it reads "NO PEDAL MOVEMENT SEEN"
What could possibly be going wrong here?
