Reply To: Rocktron ALL ACCESS/HEX expression recognition?
Home Forums Products Rackmount Rocktron ALL ACCESS/HEX expression recognition? Reply To: Rocktron ALL ACCESS/HEX expression recognition?
#134239
999
Nick: I want to thank You for all Your help, as You were right when we spoke on the phone earlier… The Hex's impedance is too high for the Eclipse. After going out and picking up a different pedal, that verified everything. I now have 'Busy' signal from the new expression pedal. Only problem I'm having now is assigning WET/DRY MIX as a Hot Key. I've tried two times now, and the Eclipse froze both times… Perhaps an update is in order. Does anyone else have this (global) parameter as a hot key?
