Home › Forums › Products › Stompboxes › Midi Expression Pedal › Reply To: Midi Expression Pedal
February 12, 2012 at 5:19 pm
#134240
Quote:
Now, I'd like to use the MFC10 to replace the 3 external Aux switches…
I couldn't get to the MFC10 manual without "signing in". I did read the MFC Setup List document, and it seems to indicate that the MFC10 switches can only be programmed to send MIDI note values. The 'Factors receive MIDI CC values, so it doesn't appear to be possible (without an external MIDI translator converting note numbers to CC values).
