Home › Forums › Products › Rackmount › vsig problems › Reply To: vsig problems
Hi nick
i am getting errors on every patch i ' get ' and then try and send.I can get them fine.The only one that works is the ' thru ' it seems.
I get messages like these relative to the patches
ams lucky man
ERROR:: 'in sw' is not an integer.
Line 2
ERROR: '0' is too small.
Minimum is 1
Line 2
Multi tap delay
don't know about an operator type 'taps'
ERROR- no operator of type taps.
Line 2
Vai shift 1
don't know about an operator type 'MEext2'
ERROR- no operator of type MEext2.
Line 4
Every patch in the Factory , user / card memory does this or everyone i tried accept the empty / thru ones.
Show More...I have tried update to 5.5 which i thought may help or cure any issues with the H8000 database ? which i thiought maybe the issue as you suggested , i have made sure that the database i download from the machine is the one vsig is seeing and tried all versions of vsig , each time witha fresh database downloaded from the actual machine.
Could this be a midi issue ?
I managed to install a serial card today in my daw as its Mb doesnt have one and that doesnt work , i cant even get the H8000 to see the serial ports on the card or ' get database ' doesnt work at all so its like a major confusion here , especially as i have had vsig running on and off for 4 years now on various installs and i am sure on this daw.
The errors suggest maybe what you initially suggested ? is the database being corrupted on download from the machine i wonder ? would a 5.5 update which i did not fix that in the machine ?
Its like their are missing modules in the machine.
Maybe a deep level reset of the machine is in order ?
