Home › Forums › Products › Stompboxes › Timefactor stuck in update mode › Reply To: Timefactor stuck in update mode
April 3, 2012 at 7:38 pm
#134382
Do not run other applications while doing an update. Do not run other applications that use the pedal when you are trying to update it.
Please close all other applications and disconnect all USB cables except those going to the pedal or necessary keyboards, mice, etc. Then try the update again (a few times if necessary). If unsuccessful, try support@eventide.com.
