Home Forums Products Rackmount Control DSP4000 thru sysex from Max Msp Reply To: Control DSP4000 thru sysex from Max Msp
#134400
    Sorry – the old method is not documented – it is there for use with sequencers, that record it and play it back. It was never intended for use otherwise and is too complex to explain.
    To a lesser extent, the same is true of the "new" method, but this is simple enough and can be explained:
    You will be familiar with the first few characters (F0 1C 70 1). The 3C is message type SYSEXC_USEROBJECT_SHORT.
    Following this is an ascii hexadecimal value F0001 – this is the identifier for the parameter you selected.
    Then a space.
    Then, the value for the parameter, ascii value 209. This is probably also hexadecimal, giving 521 in decimal.
    So, if you were to return this message, with a different parameter value it would adjust the delay. Note that preset parameters, like this one, only apply to the particular preset.
