Home › Forums › Products › Stompboxes › Will a Boss FV500H exp.pdl work with Eventide stompboxes? › Reply To: Will a Boss FV500H exp.pdl work with Eventide stompboxes?
#134401
badmelonfarmer
    Understood… Re HIgh and Low impedance … Although in all honesty I have used the L version cot volume too without the drama I expected.
    The splitter box I had made was all TRS … Let me go and check again as it was years ago that I was using it with my TimeFactor and ModFactor then the PitchFactor… But I changed to Mission Just after the PitchFactor came out
    Let me go and check to see if it works with Space as I would probably have only used the mission with Space…. But it is still a TRS.
