Home Forums Products Stompboxes Will a Boss FV500H exp.pdl work with Eventide stompboxes? Reply To: Will a Boss FV500H exp.pdl work with Eventide stompboxes?
#134402
badmelonfarmer
    Just checked, buth TRS and Mono worked fine, TRS seemed to work out of the box as I would expect…. Heel = 0 Toe = 90 (need to calibrate I guess)
    Interestingly Mono worked the other way and I had to play with the knob on the side to get it to go from heel = 100 to Toe = 0
    Either way it works, but would need a little calibration work.
    Tried it on a couple of stock presets ModEchoVerb and Blackhole.
    I double checked and I do have the L version.
    Cheers
    Martin
