Home Forums Products Stompboxes Ground Control Tap Tempo Reply To: Ground Control Tap Tempo
#134405
sjoplin
    I've been using the aux switch setup with my ground control for a while with no problems. Am able to adjust tempos and see the various tempo values change on the TF screen. Not in front of my rig to compare setting on ground control or TF, but it does work, keep at it.
    Sean
