Home › Forums › Products › Stompboxes › Will a Boss FV500H exp.pdl work with Eventide stompboxes? › Reply To: Will a Boss FV500H exp.pdl work with Eventide stompboxes?
#134422
wilkinsi
    I connected the stereo jack to the Space. The SPC manual says move the exp pedal to heel, the EDITED LED flashes (briefly I might add), then move the knob to be controlled. By the time I move the FV500's pedal position, its already controlling two parameters I don't want. The EDITED LED also stops flashing/goes solid very quickly. Do I need to clear the exp assigns somehow? Is there a more intuitive way to assign the pedal to knob functions? All I want to do is control the Pitch A and B, so that when A moves to a positive amount, B moves to a negative. On another preset, I want the FV500 to adjust between Flange 100 and Sweptverb 100.
