Reply To: New routing
Home Forums Products Rackmount New routing Reply To: New routing
#134518
You can go from analog to FW2, but this may limit some of the other things you can do simultaneously, for example you could not at the same time run all 8 channels of FW1 though the dsps, but you could connect them to (say) ADAT out.
Again, the Routing Utility will answer your questions better than I can – there are so many possible options, that things become complicated.
