Home Forums Products Stompboxes POD X3pro + TF + GCP/GCX Reply To: POD X3pro + TF + GCP/GCX
#134588
ok i am going to list what my TF has listed in the settings; however, i did call line 6 and it does seem as if the POD X3 has aset midi functions meaning there is not a way to change anything in there other than what midi channel the POD receives.  for instance CC6-15 i believe switches the amps on and off as well as volume in the pod.  now physically i have the GCXmidi out to TF midi in TD midi out to POD midi in.  once again pod midi channel 1 and TF midi ch 2.  so physically they are hooked up backwards.  Line 6 asked if TF was sending anything else out that would be changing the amps on/off.
here is tf in set up mode:
Pod set to midi 1 in pod and gcp
TF set too midi 2 in gcp
Gcp instant access button is ch 2 cc 7
TF midi
RCv ch 2
Xmt ch 2
RCv CL byp <7
Xmit cc pdl < 15
RCv map
Xmit map 1:1 <0
Ctl Xmit off
Pgm Xmit off
Sys Id id 1
Output thru
When I hit button 8 the delay comes on and I lose one amp setting line 6
 hope this helps i maybe stuck,
rex
