Home › Forums › Products › Stompboxes › Is this possible via midi with the Timefactor? › Reply To: Is this possible via midi with the Timefactor?
June 22, 2012 at 6:39 pm
#134641
The TF should be sending the correct MIDICLK OUT after a preset change and/or MIDI PC. I know this b/c another factor pedal correcty follows the change. I would check with the Adrenalinn guys to see if that box looks for MIDICLK data after a Program Change. Does the Adrenallinn MIDICLK follow any other boxes after preset change?
