Home Forums Products Rackmount noise with Black hole pgr on Eventide H8000fw Reply To: noise with Black hole pgr on Eventide H8000fw
#134677
    Does the problem only occur when running the reverb on DSP A ? This would suggest a hardware problem (fault in delay memory) which is more likely to occur on DSP A. If this is the case, you could either only run these reverbs on DSP B, or send it in for service.
