Home Forums Products Stompboxes Expression pedal on TF for delay input ? Reply To: Expression pedal on TF for delay input ?
#134692
ndeshpande
    At this time, you can't control the input gain on the TimeFactor. Although this is unsupported, my suggestion would be to get a splitter/mixer or true bypass loop, and then put a volume pedal in front of the TimeFactor but after your signal has split.
