Home Forums Products Stompboxes Really Need your help guys Space pedal (need kevin shields reverse reverb sound) Reply To: Really Need your help guys Space pedal (need kevin shields reverse reverb sound)
#134718
ndeshpande
    The sound in that video is coming from a multi-tapped reverse delay line, which Space doesn't do. If you want that sound from an Eventide stompbox, I suggest you look at the TimeFactor, MultiTap mode will get that sound.
    The closest you can get to that sound on Space is with Blackhole. Inverse Gravity at 100 (decay knob all the way to the left), size somewhere around 35, no predelay, feedback around 80, modulation and eq to taste. Not precisely that sound, but it's certainly something. Turn up the modulation depth, crank your amp's gain (once again, careful not to damage your hearing!), and you should have a half-decent MVB swirly wall-of-sound reverb going on. Again, experiment with distortion before and after (or even none, if your amp gets heavy enough) and you should be close.
    Thanks,
    Nikhil
