Reply To: ModFactor Wah – Midi Expression
Home Forums Products Stompboxes ModFactor Wah – Midi Expression Reply To: ModFactor Wah – Midi Expression
#134748
Thewalkindude
Thankyou very much.
It appears that I was setting the CC value – I was doing the first method – lowest to highest value through the expression pedal calibration method.
Although, even when I had the Midi out on the FCB1010 connected to Midi in on my Mini Amp Gizmo and both were powered up, the FCB1010 still showed F1 (no midi connection present) when I entered the expression pedal calibration process. Not sure why this is the case…
