Home Forums Products Stompboxes Can I make the time factor get that sweeping effect when adjusting the delay rate? Reply To: Can I make the time factor get that sweeping effect when adjusting the delay rate?
#134752
ndeshpande
    I've been sitting down with a TimeFactor for a bit. While the TimeFactor does have many sounds, you are correct in that it won't do the sounds you've posted in the video. There are a lot of other pedals out there that will, though, and a decent number also have expression pedal inputs.
    Thanks,
    Nikhil
